1 - 5 of 5 Posts
ive decided my socket 478 is obselete, i have to buy ram, new mobo and probably a new gpu, so i figure hell, mine as well get s socket 775 cause the 478 is outdated and get a cheap 805 2.66 and try to OC it to 4ghz, so now fo rthe question, whats the best mobo for a 775? lol a nice run on sentence.
Originally Posted by TrueNoob
i was looking at about 120, it all depends on what i get for xmas
Well, you do want a 975X for that CPU to do a really good overclock. And you do want a REAL good air cooling or water cooling system if you intend to over drive that power hog CPU.
Also, you might need a decent NorthBridge heatsink/fan combo. Depends on how high the FSB gets and all that.
So, 120$? Maybe you want to only overclock a little and use the stock Intel cooler (not that bad). Then you can buy a cheaper mainboard.
1 - 5 of 5 Posts
