Hi all,
Finally looking to upgrade my GPU since my 560 non-Ti has been choking since I got my new monitor (1440p res).
Was considering a GTX 670 4GB since I have a few EVGA bucks but I keep reading about how the 7970 3GB is better due to higher memory bandwidth. Also because the cards come with Crysis 3 right now hehe.
The main option I'm looking at right now is the XFX 7970 GHz Double D 3GB. NCIX has it for $430 before $30 rebate, and I have a $20 coupon for NCIX. So its looking pretty good in terms of price (GTX 670 4GB would end up costing me the same amount though, in case anyone wants to push me in that direction).
My question is though, I know the XFX is reference PCB, so thats good for WC. But is the voltage unlocked? Is XFX good with their QC/binning?
I've seen a lot of different recommendations on this boards (a lot for the Sapphire Vapor-X) but that card isnt reference PCB so no full-cover blocks available.
Do I bother with GHz edition if I'm going to throw it under water and OC it myself anyway?
Suggestions? Thanks!
(Rig is in my sig, its up to date)
EDIT: NCIX has a decent deal on the MSI 7970 OC 3GB, would cost me $20 more than the XFX and it sounds like MSI keeps all their cards unlocked. Is this correct? If so should I just go for that card?
