Best Agp Card
1098 17
SO I have this lame Mad Dog MX4000 nVidia and it sucks
and I have like 160 to spend on an new agp card
and unless someone knows where I can get a MOBO for my 478 CPU
that has PCI-e
im stickin with agp
i was lookin at a x800 or x700
found some for like 100 but i dunno
what should i buy guys?
1 - 18 of 18 Posts
Well the 7800GS is coming out next week, so that will be prolyl the best AGP card beside the x800xt PE? i beleive it is....
http://www.overclock.net/nvidia/7034...oming-out.html
Sorry for 160, i think the 6600GT would be your best card, that or the x1600PRO....
I have to say the 6800GS. It is a little expensive, but it is a kickass card.
Then there is always the 6600GT. Solid performance without a huge hit on the wallet.
Also, get the VF700. You can get it with the 6600GT, or get the 6800GS, save a little, and get the VF700 later.
here is pci-e socket 478 mobo, and i reccomend 6800gs or the new 7800gs... depends on you budget, but for under 160 prolly the 6600gt
i say go for the 6800GS. scrounge up a few extra pennies and buy that. then overclock the hell out of it.
however, i will say that compared to your MX4000, even a 6600GT will give you a huge performance boost. so if you don't want to wait longer to buy a new video card, the 6600GT would not be a bad card at all.
make sure you skip the 7800GS... read the review on it at HardOCP. the performance you get is not worth the price.
EDIT: okay if you actually only have 128Mb of RAM, then buy the 6600GT and go spend 20 bucks on at least 256Mb of generic RAM... try to get 2x256 of DDR if you can. they're really cheap on newegg. that will be a much better option for you.
No graphics card is gonna help with only 128mb of memory, even loading Windows XP with that little memory is a pain.
But an X1600 XT would be the best bet for your price range, it kicks the 6600 GTs ass, especially in newer more demanding games, and games that have yet to be released will also perform even better on the newer architecture.
thehybridpyro,
If you can find one, I would suggest getting an X800Pro VIVO. It must be the VIVO version though, as this version has a very high probability of being able to have 4 extra pipes unlocked, giving it the full 16. I got an X800Pro (non-vivo) recently and although I cant unlock the extra 4 pipes, I can overclock the core by 18% and the memory by 27%, stable, which exceeds not only X800XT clock speeds, but X800XTPE clock speeds too. If you get an X800Pro VIVO, there is a good chance that you will be able to unlock and clock it to be a full XTPE, which is pretty good for a PRO price.
I would avoid the X700 Video cards though, as they have (to my knowledge) only 128-Bit memory bandwidth, which isn't any better than an 9600Pro/XT had. They do out-perform a 9600XT, but their performance (at least in benchmarks) isn't really much better than an overclocked 9800Pro/XT, which is a previous generation of card.
Anyway, that's my
, for what it's worth. Good Luck with your search for an affordable and decent video card!
Highly-Annoyed
well ill say x800pro its a good card that can oc well and if u get one that can unlock to 16 pipes all the better
a mate of mine has one with a amd 3200+ 2gig of ram and scores over 7000 in 3dmark05
hes PC is oc a lot but still a good score for that set up
sry off topic
Highly-Annoyed we have roughly the same specs
just wondering what scores u get in 05?
as I'm not doing to good
6823 is the best i got
sry off topic
I currently get 6118 @ 560/1120 in 3DMark05. I can push about 20-30 more Mhz out of my video RAM and another 10-15 Mhz out of my GPU, but I'm waiting for my recently applied AS5 to cure before benching much higher than I have at the moment. I'm hoping to reach a stable 580/1200, but even if I get this, I don't see my score going much above 6250 at most, as my RAM is too weak to allow a higher CPU O/C than I already have... See my public profile for more info
Sorry for the
post thehybridpyro
Highly-Annoyed
Sorry for the
post thehybridpyro
Highly-Annoyed
I got the same card as you and yes, it overclocks like mad, were you able to unlock any pipes however? A kind overclocker on this site sold it to me for 200$ shipped which is a good deal in Canada. I would get a 6800 vanilla instead of the 6600GT; its got more pixel pipes, may be unlocked and overclocks better
7800GS is the best AGP card out, it is out already.
Discussion Starter · #15 ·
im gonna buy a gig of some high end OCZ or BALLISTIX SO
DONT WORRY bout my RAM guys
the 7800GS is a bit expensive for me but maybe ill get lucky
x800PRO VIVO looks great ill prolly go with that
cuz the 6600GS is around $200 and Icant find a 6600GT cheaper the nthe X800
thanks guys
Discussion Starter · #17 ·
check my case mod page in my sig for the stuff im thinking of buying for my rig soon
for those of you too lazy,
some 450-500 watt power supply
a gig of pc4000 ballisitx
fans
other crap
I know some of my suff is lame
but Im broke at the moment
wating for my buisness to kick up
At stock reference speeds, a 7800 GS is slower then an X850 XT PE.
When overclocked, it can pass the X850 XT PE at stock speeds, but there is yet to be a review of an X850 XT PE overclocked (they can still go further with good cooling) vs a 7800 GS overclocked.
1 - 18 of 18 Posts
