can't decide.. in a pickle.. need advice.. so lost and so many options
You MIGHT run into HDD running a bit hotter then you want, though, with the second chamber not having any airflow.
I surely wouldnt run any sort of data storage on plastic easily-removable trays. Its asking for an accidental disconnection or static discharge. I still liked the case for the time I had it.
Review is useless, as there is no info on what was used for fans in the case. As the S340 do not come with any in the front.Originally Posted by a11an
S340 is no way the best aurflow case under 100$.
http://www.bit-tech.net/hardware/cases/2015/03/18/nzxt-s340-review/3
