1 - 12 of 12 Posts
Goodbye
A.C. Freezer 64 Pro<br><br>
Dirt cheap and does a great job cooling my system. Runs about 41C no matter how high I clock this rig and no matter how voltage I pump into my CPU<br><br>
And it's pretty much silent
I just wanted to say that I agree with Penicilyn.<br>
The Arctic Cooling Freezer 64 Pro is good and costs less than 20€.<br><br>
Much stronger but slightly over your limit is the Scythe Ninja for about 40€.<br>
I guess its the strongest AM2 cooler.
ZALMAN CNPS 9500 AM2:<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118004" target="_blank">http://www.newegg.com/Product/Produc...82E16835118004</a><br><br>
Just an idea <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
There are plenty here:<br><a href="http://www.frozencpu.com/search.html?mv_profile=keyword_search&mv_session_id=KtNkWNAX&mv_searchspec=AM2" target="_blank">http://www.frozencpu.com/search.html...searchspec=AM2</a><br><br>
Scythe Ninja is not the best. I think either of these (including the heavier Scythe) will beat it.<br><br>
However, also keep in mind what you want to do with your rig. If yuo move it a lot (lanparty), take the weight of the cooling in mind. Many of the ones below weigh up to 2 lbs, while the Arctic Cooler and Zalman are a lot lighter.<br><ul><li><a href="http://www.frozencpu.com/products/5232/cpu-noc-03/Noctua_NH-U12F_CPU_Heat_Sink_Socket_754_775_939_940_AM2.html?tl=g40c14s220" target="_blank">Noctua NH-U12F CPU Heat Sink</a> $64.95 - Expensive, out of stock, but possibly the best out there.</li>
<li><a href="http://www.frozencpu.com/products/5088/cpu-scy-09/Scythe_Infinity_10-Heat_Pipe_CPU_Cooler_-_AM2_Ready_SCINF-1000.html" target="_blank">Scythe Infinity 10-Heat Pipe CPU Cooler - AM2 Ready</a> $57.9</li>
<li><a href="http://www.frozencpu.com/products/4015/cpu-tri-27/Thermalright_SI-128_-_Athlon_64_and_Pentium_4_S775.html" target="_blank">Thermalright SI-128</a> with <a href="http://www.frozencpu.com/products/4019/cpu-tri-25/Thermalright_AM2_RM_Rev_A_Heatsink_Bracket_for_HR-01_Ultra-90_SI-97A.html" target="_blank">Thermalright AM2 RM (Rev. A) Heatsink Bracket</a> $52.98 - you'll need to add your own 120mm fan</li>
<li><a href="http://www.frozencpu.com/products/1469/cpu-tta-26/Thermaltake_Big_Typhoon_VX_5_in_1_CPU_Cooler_w_Heatpipe_Cooling_Technology_CL-P0310.html" target="_blank">Thermaltake Big Typhoon VX 5 in 1 CPU Cooler w/ Heatpipe</a> $52.95</li>
<li><a href="http://www.frozencpu.com/products/1490/cpu-zal-21/Zalman_CNPS9500_AM2_Ultra_Quiet_CPU_Cooler_AMD_AM2754939940.html" target="_blank">Zalman CNPS9500 AM2 Ultra Quiet CPU Cooler</a> $64.95</li>
</ul><br>
These are the big guys. The Arctic cooler will do a good job for about half the price. However, you'll see a bit lower temps with any of these heavy duty cooler.
yea, that arctic freezer is a good product since its so cheap. does a great job for around $30 usd.<br />
i bought the freezer 7 pro for my c2d since my zalman cnps9500 was a complete waste of money. ($65 at the time!)
Old school
The Zalman 9700 is out, haven't seen any tests with those yet though. It has a 110mm fan instead of 92mm and also weighs a bit more.
The Thermalright 120 Ultra is actuall a very good unit. Right on the heals of the best within .5c! The bone job is you have to fork over an extra $7 for the AM2 mount kit!
I like my zalman. The highest temp my cpu has ever gotten was 38*C And thats after I've been playing BF2 for a couple hours. <br />
I would say save up a couple extra bucks, but thats just me.
I have no issues with my AC 64.<br>
Quiet, cheap (got mine for $20 shipped) and works well.<br>
I have my 3600+ OC to 2.95ghz and I don't get over 48°C in orthos or while folding. Idle is around 32°C<br><br><i>edit:</i> Wholy old post revival Batman. I did not notice the original post date when I responded.
1 - 12 of 12 Posts
