1 - 11 of 11 Posts
Perhaps I'm a bit spoiled with my fully aluminum Thermaltake Xaser III, but it seems like the quality of new cases are pretty flimsy these days.. I mean the Thermaltake Level 10 looks outstanding aesthetically, but it's thin enough to bend quite easily.
The biggest issue I have with my Xaser III is that it's quite heavy.. but it is a pretty big case.
What would you recommend for the best ATX Full Tower out there? For silent computing, easy access to components, and for lowest temp levels?
Thanks
Originally Posted by shinigamibob;13080763
Just want to point out thst the link you provided is for a haf 932, not a haf x. The haf x is significantly more expensive than the 932, even though they are almost identical in operation and aesthetics.
Yeah, I just noticed that too. Thanks for pointing it out. The HAF X is huge!!! Looks very nice though
You're welcome. Also, the haf 932 and the haf x have almost exactly the same dimensions.
1 - 11 of 11 Posts
