Best Bang for your buck card (around 100 bucks)
529 Views 6 Replies 7 Participants Last post by  Mccaula718
would like a card that can run crysis (fairly well) in hd 1080p/1920 x 1080
for around 100 bucks, is there such thing? lol if not what would you say the best card for that price range is?
was looking at the Radeon HD 4830 512MB 256-bit GDDR3
http://www.newegg.com/Product/Produc...82E16814102803
1 - 7 of 7 Posts
Crysis... What resolution? Because I don't think $100 is gonna cut it...
For $113 you can get a 4870 that might fit the bill
Yeah, the HD4830 is great bang for buck. I believe it can be found cheaper then $100 though.
Also, soon there will be new cards such as the HD4750/HD4770. These cards will be released the 6th of april, and then there will also be a price drop.
I agree with this best bang for the buck
4830. or you can wait for the 4770. but i doubt that you can max crysis with that resolution. that 4870 posted above is a really great deal.
That is a really good deal for that card. You probably won't find a better value than that if you don't mind the $30 rebate.
I bought my 4850 openbox for $103 last week. This would be your best bet for your 100 dollar budget. If you want to get brand new, you can get a 4830 and overclock the hell out of it.
1 - 7 of 7 Posts
