Originally Posted by xandypx ![]() Here is one "serious" fan to consider. It is a ball bearing fan, and comes with a controler. It can be loud when on full speed, but can push 110cfm at full speed, typical of all ball bearing fans, it will be slightly louder than a sleeve bearing, but will have a longer service life... Don't beleive Cooler Masters claim to silent operation... silent operation is 1100 RPMs and under. The nice thing about this fan, is when using the included speed control, the led lights don't dim. Just adding a controler to a standard blue led fan, also reduces the voltage to the leds, and the leds dim consistant with fan speed. More expensive than the typical 120mm fan, but IMHO.. this ones a winner. http://www.frozencpu.com/products/69...6c15s518#blank |
Speaking of the brightness, how bright would you say these LEDs are? |
Originally Posted by slngsht ![]() I had a blue LED fan in my tuniq, and you can't see it. You see a faint reflection off the motherboard, but that's it. |
Originally Posted by mfb412 ![]() thats right, ive seen a tuniq with a led fan on it, and you cant really notice... youd be better off with a silverstone FM121 or the likes... |
Originally Posted by xandypx ![]() More expensive than the typical 120mm fan, but IMHO.. this ones a winner. http://www.frozencpu.com/products/69...6c15s518#blank |
