1 - 9 of 9 Posts
Asus WS revo or the Extreme7 Gen3, personally I would go for the GEN3, it looks too sexy
EDIT:
The only other two, the M4E Z which you mentioned above and the Z68 UD7 which is similar in price to the M4E, however the P67 UD7 is the same price as the Asrock Extreme7 GEN3.
The P67 models of the M4E and Ud7 are around $300, so that could be an option, the Z68 features are just meh (ssd caching and lucid vitu - onboard gpu)
Nvm.
Yeah I'd probably go with the ASUS P8P67 WS REVOLUTION
The Asrock would be my pick. It has perfect spacing for 3 cards as long as you have clearance between the bottom of board and your case.
MIVE is best for benching.
for gaming.. as long as it can do x8 x8 x8 you'll be fine.. it comes down to aesthetics and manufacturer preference... doesn't really matter in the end imo
spacing wise.. p8p67 ws, evga ftw, asrock extreme 7, all basically the same.
evga ftw is nothing but pci e slots.. i had it and i think it had the best spacing besides the p8p67 ws
1 - 9 of 9 Posts
