1 - 11 of 11 Posts
Ok so im building myself a itx rig now i know everything going in except video card whats the best i can get hd6670 or gt540 perhaps ?
low profile/ single slot pcb about size of pcie slot
Which case and motherboard do you have in mind?
Mini-ITX Case like Lian Li PC-Q08 can actually take in dual slot full size graphics card. See pic below for an example.
If a dual slot card can be accommodated, short length cards like these can be considered:-
1) Inno3D GTX 550 Ti (the length of the PCIEx16 slot)
http://www.qk123.com/archives/54071
2) Inno3D / Elsa GTX 560 Ti (just a little longer than a PCIEx16 slot length)
http://www.inno3d.com/products/graphic_card/gf500/gtx_560ti_2.html
http://www.expreview.com/17164.html
Discussion Starter · #6 ·
Thanks the case is a Lian Li PC-07
Discussion Starter · #9 ·
Laptop Enthusiast
the 6670 would dust the GT 540.
But good on you for finding the GTS 450.
Already have the case? I have the Silverstone SG05B-450 and it will hold a lot of newer cards. Pictured is my 4850 but my 560ti will also fit in there.
1 - 11 of 11 Posts
