Originally Posted by gunhound45
what exactly are you looking for?
-Budget???
-Noise levels
-Cable Management
-Watercooling support
-Aggressive or simple look
-Size
-Cooling capability
-anywhere under £70
-any noise level as that dont bother me with surround sound
-any cable management because i can buy clips to sort that
-i dont and wont need watercooling so that doesnt matter wether it has it or not
-any look as long as its black or black and silver , and it needs to have a side window
-cooling - id like 1 or more fans on the front , and on the back , any other (example - top) would be a bunus though
so pretty much anything similar to the antec 600 , also is there a version of the antec 600 which is fully black instead of black with a silver trim ?
