Best cheap case?
670 Views 10 Replies 7 Participants Last post by  noobdown
HI, as some of you may already know I am doing a build for my parents, and they don't want a fancy expensive eyecandy case. They basically just want something that isn't beige and is sturdy...oh and they want to spend $25 or less on it.
Any suggestions?
Thanks!
1 - 11 of 11 Posts
Take your pick. They're all about the same build quality
http://www.newegg.com/Product/Produc...page=1&bop=And
off topic but..Jester, your avatar is sick!
Do you have a Micro Center near you...
http://www.microcenter.com/single_pr...uct_id=0237019
Nice case/PS for a nonOCes sys.
Off Topic, Jesters Avatar RULES
That there duke is like the ideal case for my parents, too bad it costs too much! hmm...are there any other cases (possibly not from the egg) that any of you would recommend for under $25?
Yes, I have been told my avatar rules. That is why I shall never change it! *looks toward the sky, whilst reaching out*
Good luck. I recently bought Cooler Master case for 40 bucks and it's got really thin sheet metal. Also a bunch of really sharp points inside too. But for the price it looks good and works for me. I don't think I'd spend any less though unless it's something used.
With a PS that not a POS, sorry, not clue!
Look for a cheap Chieftec case. They have amazing build quality for the price and they're cheap too.
1 - 11 of 11 Posts
