1 - 9 of 9 Posts
Hi all,
After a recent reinstall I can't see video in Winamp. I forget which codecs I had installed on my old system but have heard that some can be nasty. Which ones are recommended?
Thanks
Gary
Originally Posted by algae
Hi all,
Thanks
Gary
Hi,
Go to Free-Codecs and download the K-lite codec pack or alternatively download VLC media player and not have to download a codec pack again!
1. my first suggestion is to use vlc... been using it since its inception... great piece of software
2. if you must use another media player, only download/ install the codecs you need, not packs... odds are, you wont need the multitude of codecs that those packs contain, so just install what you need
I also use vlc, it's a great little program. Not sure if it matters when viewing through winamp but DivX 6 is an essential codec IMO. Just make sure you scan for adware after you install. It'll be clean after you install and scan it.
Discussion Starter #5
Thanks guys. I already have VLC but I don't get any sound from my rear speakers when playing a music video.
G.
Uhh yeah...
2) Klite codecpack...uninstall all your old drivers...clean registry...install
XVID was never so nice
1 - 9 of 9 Posts
