Coolants don't really affect your temps. It's more there to keep your loop clean from algae and corrosion. The rule of thumb is 95% distilled water and 5% additive/coolant. You could use Zerex or car coolant for the 5%.
Originally Posted by nikon-x i did some experimenting myself, reguardless water is the best cooling medium still. If you want to do it right, buy a res and custimize it to where you can run a coil through it (water chiller) and use water with some additives. You shouldnt be worried about leakage, if you put the water kit together correctly. You have the same mobo as me, you need a chipset waterblock if your going to overclock. |
Originally Posted by Pacman I am using the coolant that came with the big water...(thermaltake), withouth water... it says"Coolant may operate withouth extra liquid" so i just put it... and no water.... Should i have put water to have better temps?? |
