It's actually best in most cases, and cheaper, to make your own. I just learned this myself as I am also just starting on water cooling.
Get 100% distilled water, an anti-algae treatment, and a UV Dye of your choice. This way you get an almost infinite supply and temps will be as good or better than the premixed stuff.
Put some water in, put just a drop of the anti-algae chemical in there, then keep adding the UV Due until you get the desired tint you want.
Hope this helps
Hope this helps
