My tower is the xigmatek asgard II, I can't seem to find the measurements for it? I am running a 92mm cooler on my rig but I have upgraded to a true x4 and want to get a 120mm cooler that will fit my mid-sized case. Any help or suggestion will be gladly taken.
Thanks, fools79
P.s.- if it helps I have about an inch to an inch and a half of room between the top of my cooler and my side panel.
Thanks, fools79
