Ok so i got a E8500, i am going to OC it to as much as i can later on, but atm i can not because my CPU gets WAY to hot, it reaches up to 60-70 With out OC on full load. I've been looking around and saw the Zalman 9700 is suppose to be good, Noctua NH-U12P, 120mm Fläkt, 1300RPM, 19,8 dB(A), or something else. But its those two that im most up for atm, they arent to expensive and are suppose to be very good. So wich one to choose or should i choose something else? I want to hit a temp at around 50 with a good OC at full load atleast.
