1 - 20 of 28 Posts
I'm not totally new to OC'ing, but there is more that I don't know than I do know. I'm looking to upgrade my Athlon XP 2600+ 266MHz FSB, and I'm looking to do it with a tight budget. So far I've found an Athlon XP 2800+ Barton 333MHz FSB, which according to the specs, the stock speed is the same as my current OC'ed speed. How much better is the 2800+ with a 333MHz FSB than the 2600+ with a 266MHz FSB?
Originally Posted by brahmabull754
They only seem to have the 2400 with a stepping code starting with I
Yeah that's the right one, u may be losing some initial clock speed but you end overclock should be better since you're using an "I" XP-M.
Discussion Starter · #9 ·
Think it'll go near 2.5 GHz?
Discussion Starter · #13 ·
Originally Posted by ShawnMcGrail
Well... if you wanna switch to Intel... $120 for a P4 2.4AE (prescott)... I've got mine to 4.012Ghz on air... lol... I'm like ThE_GeNeRaL of cpu's... trying to steal ppl over to intel...
lol
DOWN WITH INTEL!!!!
lol
lol
lol
AND no one coming too!
1 - 20 of 28 Posts
