Best driver for 6600 GT ??
7060 6
my card is MSI GeForce 6600GT
i'm using the orginal driver (6.14.10.7772 - nVIDIA ForceWare77.72)
should i update my driver ??
if I should .. please give me the link for the best driver for my card
1 - 7 of 7 Posts
http://downloads.guru3d.com/download.php?id=10
This page has a lot of different ones to choose from. Try a few of the latest ones and see which is best for your system. Every rig will have a best set for it's setup.
I run the 83.40 whql and havent had any problems with them yet. The 81.98's performed well too.
http://downloads.guru3d.com/download.php?id=2
these are "tweaked" driver sets that will most times give you a little better performance...BUT...they are NOT microsoft certified. WHQL drivers are MS certified.
yeah you should. I have a couple of those cards and I use the regular nvidia drivers... just download them from nvidia.com. I've found they tend to give me better performance than most leaked drivers
thanks guys ..
but i have posted the wrong card
this is my card specifically 6600GT-TD128E
that wouldn't change anything .. would it ?
and please .. could u give me a program to do tests with .. in order to check driver's work ??
I use 77.77, and it is the most stable that I've found for my 6600gt, seems to work well on the dual core front as well, got my fps up by about 5-10 on source games too
I would never trust the drivers on the disc, they are usually AT LEAST two months old. Just go to the nVidia website and get the latest ones.
1 - 7 of 7 Posts
