1 - 17 of 17 Posts
ok guys i have windows 7 installed what is the best driver version for my rig
do note my cpu is weak so a driver version with less bottlenecking would do good
which driver version example 191.xx or 182.xx
I heard the newest 195 is pretty good, if not 186 is known to increase FPS better than 191 etc...
doubt you CPU is bottlenecking too much if at all though, overclock them both and you still have a decent system
Not all versions of 182.xx.
I had problems with my 9800gtx with 182.22 causing system and video card crashes.
EDIT:.... My bad. I read your post, and must be blind... I somehow saw 182.
In my testing I found that the 186's bottleneck slightly less than the 190's and up. At least, that was the case in Crysis. Note this does not mean that the FPS will always be higher on the 186's, it just means they are slightly less sensitive to changes in cpu-speed. In Crysis.
Originally Posted by mocha989
for the 8800s get the 178.xx drivers
ok will try these and see how it goes then i will try the 195.xx and see
Discussion Starter · #12 ·
Originally Posted by the magical me View Post
how does this driver differ from the ones that nvidia makes ??
its tweaked for better performance
well supposed to
They're tweaked for better performance or stability, and sometimes add a few features to the Control Panel.
I fully support the Xtreme-G drivers, I've always had great success with them.
Either that or the 186.16 drivers.
Discussion Starter · #16 ·
Originally Posted by tha d0ctor View Post
but do you have an 8800gt?
good question
im seeing a 6200gt
1 - 17 of 17 Posts
