1 - 4 of 4 Posts
So you have asked the question as many others have "what are the best drivers for my graphics card ?" I have the answer for you, 99.9% of the time the best drivers are the latest drivers released from NVIDIA, not the betas, these ones are betta than the betas "haha...".
DRIVERS --> http://nvidia.com/content/drivers/drivers.asp
So yeah, I'll set you up with the links, just download and isntall, but remeber to clean out your old drivers first. You can do this by downloading Driver Cleaner
http://www.drivercleaner.net/downloa...roSetup_14.zip <--2.6MB
once you've downloaded that, extract then install, execute then choose the name of the manufacturer of the cards drivers that you want to clean. then start.
after that just click close and your all set to install your new drivers.
remeber, im just going off if you are looking for stability
Not really i like the beta more than the plan Nvidia drivers. Really its all up to you and your setup you'll have to look. Not everyone will get the same or better out of drivers, for me right now its the XTreme - G drivers http://www.tweaksrus.com/
-Sparda
1 - 4 of 4 Posts
