I'll be putting an H50 in my P180 Mini eventually, but I'd like to know what's the best setup I can get in terms of fan/shroud placement.
I'll definitely be using 120x25mm fans, because I don't want to use a fan controller and don't want anything noisy (and I don't know of any worthwhile 120x37mm fans that are under 30db, like the GentleTyphoons), so between the two fans and the H50 rad, that leaves me with about 50mm to work with in terms of shroud space.
What would be the best way to make use of that space? Two 25mm shrouds? One 50mm shroud (and where should I put it)? A 37.5mm and a 12.5mm shroud (and in what configuration)?
