Best Fans for a Fan controller?
259 Views 2 Replies 2 Participants Last post by  Laurence
finally managed to find myself a Sunbeam Rheobus for under £20 here in the UK, but now I need some Good quality 120mm LED fans. The noise is not really a problem , i can just turn them down with the rheobus. So proabbly some high speed fans.
Ive been looking at these, http://www.specialtech.co.uk/spshop/...cat=886&page=2
But these are the low speed 1350 ones, so use with a fan controller would be pretty pointless. So could you guys help me out with finding some LED fans from a UK SUPPLIER, as importing costs about £20, which is too much for a £5 fan.
1 - 3 of 3 Posts
I am not sure if you can get REALLY high speed (100+ cfm) fans with LEDs. There are higher RPM yates you can find, but they don't have LEDs. Scythe produces good fans as well, but they cost more than the yates. Delta makes really powerful fans (150 CFM) but they are fairly uncommon and expensive. Sorry, I do not know any UK suppliers but I am sure another member can help you.
Im not really bothered about really high speed, just high enough for a fan controller to be usefull, to be able to turn them down to silence them, and then up again when im gaming... im currertly asking a uk supplier if they can stock the higher speed yate loon UV LED fans
1 - 3 of 3 Posts
