1 - 6 of 6 Posts
Hey everyone,
I used to build custom pc's and i guess to degree still do. However my current hobby is car audio... i have an amplifier that gets pretty hot and i'm struggling to keep it cool with just fans. Now i'm thinking of building in a closed loop to cool the heatsink... my rig is pretty intense so I need recommendations on the strongest compression fittings available. I expect I'll be using standard rubber hoses... hit me with recommendations!
Hood Automotive lighting Automotive design Automotive tire Eyewear
Some hot rod cars (past) used aircraft tubing that has flexible metal on the otter shell and, I think, rubber inside. The fittings are attached to the flex-tube with a hex-nut fittings. Since its rubber inside, I would recommend Mayhems as the coolant.
Product Gas Engineering Auto part Cylinder
However, you will need to find it in G1/4 size for all the blocks out there.
Just a thought as I am into sim racing with a full aluminum sim rig with high end direct drive wheel base and use bass shakers (haptics) for chassis/engine vibration and shifting thump.
Maybe isolating the amp/s and water cooling system would work?
I use rubber isolation to isolate the bass shaker effects on my sim rig (example: seat is isolated from rest of rig so effects I want only through seat do not get trough to the rest of the rest of rig frame where I do not want them and vise versa).
Another possible problem with water cooling in a high vibration environment is the possibility of generating a lot of air bubbles in the cooling loop and more specifically the water pump that could cause cavitation in the pump which would not be good.
I'd go with Optimus compression fittings in 3/8 - 5/8 spec. Pair it with McMaster Carr EPDM tubing and these things are not going anywhere. I ran the same setup and you really need to pull/twist the tubing to get it off - after removing the locking collar.
1 - 6 of 6 Posts
