1 - 7 of 7 Posts
Im having to send my MSI R6970 Lighting back to Novatech, but If they give me an exchange whats the best Graphics i can get for around the £250 area, I got my 6970 in the sale for £199. My motherboard has a PCIE 2.0 slot so i think im limited to what i can fit... :/
You can get a PCI-E 3 card to run in a 2.0 slot so you're not limited to any cards at all.
· Junglist
7950 or a GTX670 if you can find one cheap enough.
Also, 7950 for definite and but as above suggested I don't see you getting a 670 for 250£.
Discussion Starter · #6 ·
Originally Posted by WR6133 View Post
If you are limited to Novatech then in your budget would be
Nvidia - 660ti ( http://www.novatech.co.uk/products/components/nvidiageforcegraphicscards/nvidiagtx660tikeplerseries/gtx660ti-dc2-2gd5.html or they have a reference card for £15 less) the 670 is just above your limit at £280
AMD - 7950 ( http://www.novatech.co.uk/products/components/amdradeongraphicscards/amdhd7950series/gv-r795wf3-3gd.html )
Does it matter that my MB is PCIE 2.0 and these cards are PCIE 3.0 ?
· Junglist
^nope, youll notice zero performance difference.
1 - 7 of 7 Posts
