1 - 6 of 6 Posts
Im installing my new mobo and CPU tonight, whats the easiest way to format the HD? Format now with my old setup, or install new mobo and CPU then format?
boot from cd, install windows procedure and delete the partition, reformat and your good to go.<br><br>
If not use a program like registry mechanic and delete the partition and reformat with NTFS.
Some motherboards require a reformat if you change them. So change your hardware, then reformat.
Reactions: The Viper
Discussion Starter #4
thanks, yes I know that part, Im just wondering should I do it know with my old setup, or format when my new setup is up?
Discussion Starter #5
<div>Originally Posted by <strong>Murlocke</strong> <a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1386746#post1386746"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Some motherboards require a reformat if you change them. So change your hardware, then reformat.</div>
</td>
</tr></table></div>
<br>
Ill try that then, thanks
1 - 6 of 6 Posts
