1 - 18 of 18 Posts
RTX Sight Unseen
Metro 2033 benchmark on very high ~15 runs with no crash or artificating and your stable.
IMO, 3dmark11, and any furmark (ie:MSI Kombustor) test for 10+min, then any 2 games of your choice 15+min each, if stable and artifact free in all of the "tests", then your fine.
Im meaning a dedicated program not a game. good suggestion though, might give me an excuse to buy Metro
RTX Sight Unseen
No you don't understand, the new nVidia chips cannot be tested with synthetic torture tests. You have to use benchmarks that heavily stress your GPUs(99%). The benchmarks that actually does this is Metro 2033(it puts both my 580s at 99% SLI)
Now you can use other "Synthetic" gpu benchmarks as well, but you cannot use anything based off of Furmark.
Ore Wa Gundam
I know ATiTool used to show a count of artifact errors IIRC, I stopped using that and started using GPUTool though when it came out, which is kinda similar to FurMark.
Hurr durr he's using a 470, which doesn't have the "protection" that the new nVidia (5xx) cards have.
ATI tool is still good, I use it when Overclocking, can usually tell very quickly if the overclock is bad.
Iconoclast
OCCT.
ATITool is dated and no longer really worthwhile for artifact checking.
You can disable the power throttling on the GF1x4 cards.
1 - 18 of 18 Posts
