best gpu under $100
542 Views 19 Replies 10 Participants Last post by  wallyworld96
so im building a comp, and i need to find the best gpu under 100 bucks to stay in budget. I just need something that can play crysis legitly on a 24in at 1920x1200rez..
i heard that gddr4 would be better because it can be overclocked like crazy,
I also heard that if im going with that big of a screen, i should get something that has 1gb of memory.
1 - 20 of 20 Posts
9800GT or 4830 if you must buy new. the 4850 can be had on here for $100 used and its a great card. About 20% faster than the others.
Whatever you heard about gddr4 isn't true because it doesn't change the card's ability to oc.
For 100 bucks you can either do 4830 new or maybe a 4850 used. If you can wait a little bit, ati is gonna lower their prices very soon. You won't be maxing out crysis at 1920x1200 with either of the cards, but it should be playable in lower settings. Good luck
I can't see anybody doing anyhing amazing with anything but a small portion of the ultrafast samsung ddr5 chips and theres not many cards that have those. Mostly going into laptop gpu's
but doesnt gddr4 run at lower speeds? hence making it safer to overclock more?
i was thinkin that the HD4830 was gonna be my best bet.
also, isnt buying an open box card kinda like an "at your own risk" type thing
IMO, one of the best video cards under 100 bucks is the HD4830. Here's an MSI GDDR3 version for $90 (and a $15 MIR), with free shipping. I can't find a GDDR4 version of the card for under $100, though. Maybe someone else knows of a good deal.
Not sure if it will play Crysis @ 1920x1200; you'll have trouble finding a video card that will do that for under $100 (unless you lower the detail, I guess).
EDIT: As posted above, you could always look for an open box deal on a better card.
my 8800gt played crysis fine at 1680x1050 fine at high. so at 1920x1200, you are probably gonna be able to play it at half medium/half high with a 4830 or 9800GT. (With a 4850, you may pull of all high at 1920x1200, im not sure.) With my current card I play very high 1680x1050.
Most low level cards have ddr3 and high level cards have ddr5 now. The odd one out is the 3870. You can find em with ddr4 but i don't think it helps performance any. The 4830 has more stream processors and a higher clock.
most "low level" cars now have GDDR2. The gtx295, the fastest card out, uses gddr3. Nvidia has not released a card with anything past GDDR3. The 4830 gddr3 is faster than the 3870 gddr4. Just make sure that the card u get doesnt have GDDR2 and you are good.
alright. what about with the size of the card?
i was told in order to get any decent AA/AF at that res I would need a 1GB card
well 1gb is useless on a weak card and you will have trouble finding a decent card with 1gb of Vram for $100. The power of the card is more imporatant than the memory. and DO NOT get gddr2. you could always play the game at 1680x1050 too.
ahh, yeah, i am not getting gddr2. and there is no way i am playing anyhting under native cuz the screen gets really warm anythign under native. plus, its 1920x1200, common man!
I was just checking because some people told me that the 1GB would help cover the whole screen processing it faster than a smaller. But then I read that unless you go to a 30in at the full 2650x**** that a 1GB has very little up over a 512
I would definately get a used or open-box, HD4850 they can be had on eBay for $75-110 depending on flavor or how long it was used.
ok, ok, but like i said, if the card is DOA?
Newegg Non-Replaceable 30 Day Return Policy (Open Box items):
* Return for refund within: 30 days
* Return for replacement within: non-replaceable
Open Box
This is our Detailed Open Box Item Return Policy. Newegg often sells items that are listed as "open-box." Because these items are sold at greatly reduced prices, they are subject to this limited 30 day non-replaceable returns policy. Such items can only be returned within 30 days of the applicable invoice date. “Return†constitutes receipt of the product by Newegg, and not the mere issuance of an RMA. Newegg cannot provide replacement service for these items, as their stock is limited. The entire risk as to the quality and performance of these items is with the buyer. These items have been tested for functionality, but may have superficial physical defects including, but not limited to, scratches, dings or dents. Should these items exhibit a functional defect following their purchase, the buyer (not the manufacturer, distributor, or Newegg) assumes the entire cost of all necessary servicing or repairs, unless otherwise required by law. These items are not covered by any 30-day satisfaction guarantee.
If you purchase an Open-Box product you will receive an OEM or BAREBONE item, meaning you will only receive the item itself. Accessories are NOT INCLUDED with Open-Box products, even if the missing accessory is required for the item to function properly.
sweet deal. thanks!
1 - 20 of 20 Posts
