1 - 15 of 15 Posts
I am currently running on the Forceware 197.03 drivers and was wondering is there a better set of drivers out there? as WoW wont let me use certain options in video options and i am getting lag or something when i play L4D online so was thinking that maybe its not internet lag but lag because of my driver
What would be the best driver to get?
· Premium Member
Originally Posted by Munkypoo7;13120735
Latest driver set
nVidia cards rarely have any issues per driver set like ATi cards do every now and then.
Grab 266.58 and run
Win 7 x64
Win 7 x86
Well.. I do have some issues like my screen colours messing up sometimes.. and one of my cards crashing with drivers installed.. but working fine on another motherboard..
Here is a review of driver performance over the last year (i think 4 were tested). The latest are overall the best though so go for those.
Originally Posted by ArmageddonAsh;13120748
great thanks, anything in particular i should do when removing my current drivers and installing the new ones? the last time i did a driver change was when i went from a 5850 to my 470 so had to run driver sweeper, is that required here as well?
Nope, just install it and you're good to go.
It will replace the old drivers.
· Premium Member
Just run the latest driver installer tick click "clean install" and it will install them by removing all the profiles first. Should be fine.
· Wat
Originally Posted by Mr.Pie;13157518
free bump
I would like to know
whats the best drivers for SLI 470's?
I've been running the 266.58 drivers. Haven't had a hiccup yet
I'd definitely try them out if you haven't yet.
1 - 15 of 15 Posts
