1 - 9 of 9 Posts
I'm NOT new to Overclock
The 560ti is the better card, I'd go with the EVGA one and overclock it yourself.
Comps
I would get the zodac one if I was you.
The msi one is good but there isnt much between them so get the Zodac
One is a ti, one is a non ti. Get the ti.. it's a no brainer. Much better card. Don't get a non ti, as you'd be better off just getting a 460. Basically the same card.
Guys, the GTX560ti is far superior to the standard GTX560.
You can't just look at the clock speeds, you have to take the architecture into consideration.
As has been mentioned the Zotac is not a 560ti but just a 560. I do not think the EVGA 560ti would be a bad choice if every dollar matters but as mentioned, the MSI hawk is the better card and I might even say it's worth the extra money even on a budget.
To answer you're initial question in the title though of which is the best 560 nonti bang for the buck. This one is by far.
Discussion Starter · #9 ·
$260 is too much for me. I am expecting around the range of $200 to $220.
What is the best bang for the buck GPU with only $200?
1 - 9 of 9 Posts
