1 - 20 of 30 Posts
Iconoclast
Cogage/Silver Arrow (or IFX-14), Noctua NH-D14, Prolimatech Super Mega, Thermalright Venomous-X, Thermalright HR-02...take your pick.
Reactions: pistons50
HSF list is Cogage/Silver Arrow is very good then > ND14 but its big and in most instances covers some of ya ram slots i say go for either the Venomous-X cooler or the mega shadow in push-pull
Discussion Starter #5
Thanks, I appreciate the suggestions. + Rep More would be appreciated as well. I like to have a wide variety of choices. So keep the suggestions coming please.
Old fashion Thermalright Ultra 120 Extreme is still a great contender.
Noctua NH-D14 all the way & Thermalright Venomous-X is also good
If you are on a tight budget, you might want to consider the Thermaltake Frio, which is a pretty good HSF.
If you are on a low budget, then the CM Hyper 212+, Scythe Mugen 2, Xiggy Dark Knight are great budget coolers.
As for the top end coolers, the others above me have already listed all.
Ditto, Also add in the Corsair H70. Its a sealed water loop and as easy as an air cooler install, with potentially better temps, so i would consider it.
OG AMD
TT Frio,Spire Thermax Eclipse II,Zaward Vapor 120,CM V6 GT,CM V10,Zalman CNPS,Tuniq Tower 120 Extreme.I would recommend the Prolimatech MegaShadow or Venomous X though.
Iconoclast
The TRUE copper is matched or beat by several lighter, less expensive, heatsinks.
Super Moderator
Thermalright Silver Arrow, definitely.
Prolimatech Megahalems Rev.B
There isn't a best per se, the best depends on the case, ambient temps, case temps, airflow, fans used and how much heat internal components are generating.
Some say NH-D14, some go Megahalems and some prefer the Thermalright Silver Arrow.
Just based on my experience with it I'd say D14, but I've never tried other HSFs so I can't really be certain what will work for you.
Air Cooling
-Prolimatech Megahalem Rev.B
Water Cooling
-Corsair H70 (WaterCooler w/ everything in it-pump,radiator,fan,etc.)
-Corsair H50 (The older H all-in-one waterblock)
hey my friend, if you really want a beast as your title says you wanna go for the Noctua Nh-d14,
The silver arrow is a new cooler that so far has proven to be better in recent reviews than the Noctua... to really make sure it is the new king of the hill i would wait for more real reviews...
source
1 - 20 of 30 Posts
