What is your maximum budget? $750
What country are you in? United States
What will be the uses of this laptop? Gaming/Entertainment
Do you have brand loyalty or care which brands we select for you? None
What screen size do you require? ≧15"
What screen resolution do you require? ≧1366 x 768
Are you looking to buy NEW or would refurbished/recertified/used be okay? Primarily new, but if the reliability/price allows refurbished, or recertified will suffice.
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet) At Least two hours.
What games would you like to play with your laptop? And on what settings? Crysis 2/Starcraft 2: Med-High
What operating system do you need? (if any) Windows 7 Home Premium 64-bit
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.) Gaming
How much hard drive space do you need? ≧320
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.) Nothing special, however, a webcam would be nice.
Is there anything else we need to know? (http://www.newegg.com/Product/Product.aspx?Item=N82E16834115987) top prospect at the moment.
