What is your maximum budget? 800
What country are you in? Canada
What will be the uses of this laptop? Internet/modern gaming on LOW settings/snappy multitasking
Do you have brand loyalty or care which brands we select for you? No
What screen size do you require? 15" and under
What screen resolution do you require? Best available
Are you looking to buy NEW or would refurbished/recertified/used be okay? either/or
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet) Doesn't matter, longer the better obviously
What games would you like to play with your laptop? And on what settings? Cry2/SC2/BFBC2 low settings
What operating system do you need? (if any) Windows 7
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.) - would be nice if it wasn't butt ugly
How much hard drive space do you need? 300-500 Gigs should be good (open to other sizes)
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.) No
And be faster than my current laptop!
Current laptop 15"
Model Name: MacBook
Model Identifier: MacBook4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 800 MHz
Current laptop 15"
Model Name: MacBook
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 800 MHz
