1 - 20 of 28 Posts
· Premium Member
Whats the best one for a quad? im about to sell my xig in hope for better temps.
i dont wanna spend much more than 60
^ That's a hard one.
But the closest price I can find for that and the best that matches with a lapped true with 2 fan is the Noctua nh-u12p? I think I spelled it right. (spelled it wrong now corrected)
Newegg has it for 60USD right now.
Though, it's missing another fan, but I think it should be pretty good. I was researching a lot abotu this. It's the best closest thing to TRUE out of the box. No need to lap. Lapping probably does help it, but it's good for the money.
Lapping the Noctua won't help as much as the TRUE (pretty bad stock). Either way for $60, the Noctua is probably your best bet. TRUE costs more after sandpaper and fans.
I thought the same, but it would depend. if you checked out ljason8eg, lapping it does make a little difference. But a difference is a difference. Though he did it with the CPU too. I read a lot and a lot of peopel sya it makes little different, but I was just saying that it does help a little.
And I was just ading more comment than I had to. Noctua is the best out of the box!
Socially approven?
· Premium Member
Yeah the Noctua gets my vote
· Premium Member
nactura or true
or if u wanna spend less the xiggy
· Mac addict in recovery
The Scythe Mugen 2 looks attractive, it's priced about the same as the Xigmatek S1283 but comes with a bolt-thru mount (extra cost option on the Xig). XBitLabs thinks it's better than a TRUE, though they didn't actually compare them head-to-head.
http://www.xtremesystems.org/forums/...d.php?t=211739
Is par with it but loses slightly, but then it's affordable unlike the TRUE.. both are affordable I guess, but I mean cheaper.
· Premium Member
Have had good temps with the Xigmatek 1284ee with bracket, i wouldn't use the plastic pegs on anything. Fan can be configured in push or pull. Can be a pain to setup two fans as they use the rubber pegs that lock into the heatsink fins.
1 - 20 of 28 Posts
