Best Lian Li Full Tower? Need Suggestions..
469 Views 6 Replies 6 Participants Last post by  Behemoth777
Hey guys,
I need some help picking out a case. I know that I want a full tower lian li, but I can't decide which one. My budget is anything under 300 preferably towards 200 though. I need really good airflow because I'm going to be using air cooling and I'm going to have some graphics cards that need to be cooled as well as an overclocked cpu.
Any suggestions, personally preferences, etc.?
1 - 7 of 7 Posts
Originally Posted by TFL Replica
The Armorsuit PC-P80 would be my pick.
this is what you want for epic cooling. my brother has this case and I put everthing together for him. Very easy to work on... its massive and has very impressive cooling.
It can also fit a rad quite nicely at the front. A triple rad would fit, but it would leave no room for HDD or Cd/DVD
There isn't much difference between them. Most of them are the same with the difference being the amount off hdd bays and the addition of a door. Some have a single fan up front and some have two. The P80 is the only one that looks different to me.
I don' think that full tower lian li's are best suited for optimal airflow. When I look at them, I just think which will work best with watercooling. In which case can I stuff a bigger rad and more of them.
Originally Posted by LiquidForce
Personally I like the A70 and A77
P80 if you want to spend a little more
http://www.silverpcs.com/index.php?c...4d526d6bcf41a8
Thanks for all your suggestions guys! The pc-p80 looks perfect and if I decide to go water cooling in the future, I can easily do it. The price tag is a little steep but it just looks like that's a case that could last me a freakin decade!!! hahaha Thanks guys!
1 - 7 of 7 Posts
