Hi, did you have experience with bare copper surfaces? Which one is less reactive?I recently switched back from Conductonaut to Coollaboratory Liquid Ultra and I'm never going back to Conductonaut lol.
The most longevity for liquid metal requires:Can't decide whether to use LM on gpu or not. Seems like it will turn solid no matter what you try, which is not a bad thing on it's own, but indium-tin layer appears to be fragile to any mechanical impact, which results in losing thermal contact over time and bad temps. But what is it most exposed to? Vibrations, or impulse from strong random kick, or perhaps thermal expansion cycles? Can tighter mounting prevent it? Can it actually be better to let it build a stronger bond with bare copper, or thermal cycles will damage inner structure anyway?
Let me know how it goes compared to lm
What your thoughts on silver coating?The most longevity for liquid metal requires:
Interesting. Based on the MSDS, it's a high temp mold release agent.
Terrible. Beyond terrible. So terrible you shouldn't give your worst enemy this stuff. Avoid unless you want Thermal throttle in seconds (throttles faster after the first 3 minute run!!!) and slightly burned heatsink with extremely hardened calk type powder material to scrape off. R9 290X survived and now has Thermalright TFX on it.Interesting. Based on the MSDS, it's a high temp mold release agent.
Definitely curious to hear how it works.
Good to know! Wonder how they measured the W/mK rating of that stuff. In the datasheet, it says it's a water based suspension, designed to cook off and leave a dry coating of boron nitride.Terrible. Beyond terrible. So terrible you shouldn't give your worst enemy this stuff. Avoid unless you want Thermal throttle in seconds (throttles faster after the first 3 minute run!!!) and slightly burned heatsink with extremely hardened calk type powder material to scrape off. R9 290X survived and now has Thermalright TFX on it.
