Hello,
So i've been hunting on the internet for a few hours and getting many different answers for the settings needed to get the core i7 920 to 3.6 GHz on my Asus P6T Deluxe V2 motherboard w/ some G.Skill 7-7-7-18 DDR3 1333 memory. I then came here and read the sticky'd post of one member's specs on how he got to 3.61 GHz on a similar board. My question is, would this be the best way setting wise to reach this speed or is there a way to improve? Again I am new at this so I just want other's opinion's and I know my ram setting would have to be different. Thanks in advance...
• Processor model: i7 920
• CPU clock speed: 3.61GHz
• Hyperthreading: On
• CPU Bus/Bclk speed: 180
• CPU multiplier setting: 20
• CPU core model: Bloomfield
• CPU batch/stepping: Revision C0/C1
• CPU voltage: Loaded-1.216 Idle-1.232
• Motherboard model: MSI x58 Pro MS-7522
• Cooling: Noctua NH-U12P SE1366 (Push/Pull; rear exit orientation)
• RAM size/model: 6gb (3x2gb) A-Data PC3-10700 9-9-9-24
• RAM speed: 722MHz (stock was 667MHz reported) 9-9-9-24
• SuperPI result (1M): 11.618
