Best MOBO for E8500
1208 Views 28 Replies 13 Participants Last post by  coelacanth
ASUS P5Q Pro Turbo is what I'm looking at. I am going to order the 5850, and eventually SLi them, so just looking for the best board available
1 - 20 of 29 Posts
Best board for an e8500?
That has to be the Rampage Extreme, hands down the best for high FSB.
Best motherboard for a 45nm Core 2 Duo is hands down the Biostar Tpower I45
It has reached 700mhz FSB which is absolutely insane. Proof
I like the Asus P5Q and Gigabyte GA-EP45 boards. Definitely pick one with a P45 chipset, in my opinion. Sometimes the nVidia boards overclock great, other times they don't.
If I'm not looking to overclock, and im looking to crossfire, what is the best boarD?
What's your budget?
For <$150 I'd say the Asus P5Q Pro, Pro Turbo, and Deluxe, and also the Gigabyte GA-EP45-UD3P and DS4P.
Originally Posted by The Master Chief
ud3p-ep45
Is not a "crossfire" board.
Is it the best over all 775 board? yes it is. Can it xfire? Yes it can, but will people buy it to crossfire? I dont think so.
Gigabyte gets my vote. Question, though, if you're not overclocking, does it matter that much? I'm all for a decent quality board, but why spend that $$ on a mobo when you can get a cheaper one and spend that extra on more GFX or bigger monitor etc.
Mine
Gigabyte EP45 Extreme series holds the world record for highest FSB ever
my monitor is big enough for me haha. I like that biostar board. im sooo confusedddddddddd
The best for crossfire will be an X48 board (since they have 16x/16x and P45 only has 8x/8x).
Generally they clock higher than P45 as well. To put things into perspective, I had to struggle alot to hit 4.6ghz on my P5Q-E. But using EVERYTHING on auto with the rampage extreme I can hit 4.75ghz, much less with any tweaking. If you want to see what sets WR's its the Rampage Exteme. (The biostar is no slouch either).
But if you want a decent day to day board, pretty much anything listed wont let you down. Get whatever is cheapest. Personally I like asus since their bios is better IMO, but gigabyte makes nice things too.
It crossfires... I had dual 4830's on mine..
worked great.
i have to agree if you want the best performing multiple gpu 775 board
its hands down the rampage extreme.
Gigabyte |EP45 Extreme| I cant find this board on newegg! that one or the biostar, im confuseeddddd
1 - 20 of 29 Posts
