1 - 7 of 7 Posts
I am looking to upgrade and will be running an e6600 4mb cache duo core, probably run a single card for now but i may go all out and run dual cards so needs to be SLI ready and pretty much that's all i've decided upon now..and i know i won't run any expensive cooling everything will be most likely cooled with cpu fans and extra graphics fan<br />
<br />
prefer asus or abit but please lmk guys
In my oppinion the best motherboard for oc's and performance on a core 2 duo is definatly the ASUS p5b Deluxe, but im not sure if its sli ready. Its worth checkin this out because its a great board and even if its not sli there are some versions of the board that are slightly more expensive than the deluxe model so they might well be sli. Read up about it in some reviews as all the ones ive read have given this mobo a glowing reference! Im buying one next week!!!
This is pretty much the board of choice for max OC with the e6600...<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131025" target="_blank">http://www.newegg.com/Product/Produc...82E16813131025</a>, But, if you're serious about a "modest" Overclock ( kinda an oxymoron imo, but, hey.. it's yer dime).. this is a good modestly-priced board...<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813128012" target="_blank">http://www.newegg.com/Product/Produc...82E16813128012</a>
I have the Asus P5W DH Deluxe, It's Crossfire Ready, not SLI. The P5B..I'm not sure. I think it doesn't support either. Am I wrong?
Discussion Starter #6
so this is no good?<br><br><a href="http://www.newegg.com/product/Product.asp?item=N82E16813131045" target="_blank">http://www.newegg.com/product/Produc...82E16813131045</a><br><br>
i want sli so that i can have the possibility to do so....and i read that the p4n32 sli doesn't overclock well at all
1 - 7 of 7 Posts
