Since US retailers are finally picking this up I will be grabbing the spawn soon.
Is there a clear favorite as far as pads go for this mouse?
Haven't used cloth in a very long time. I have a razer exactmat currently which is a hard surface but I have no preference.Originally Posted by FlipBack;14177720
Here we go again. Since it's optical, it will work on any mouse pad (hard or soft).
Do you prefer a cloth surface or a hard surface?
Which Goliathus is yours? Speed? Fragged edition (with the green splash)?Originally Posted by ChristianEx;14177750
To find a good mousepad I believe it's up to the individual to find one which works good for you. But what I could recommend is the Razer Goliathus, or Roccat Tatio or Sense. Thouse have been the last three I've tested out, lover them all - at the moment I'm using the Razer Goliathus. But thinking of going back to the Tatio. But again, also believe that a good mousepad is also very much up to the person using it, how you feel about it. And yeah, since it's optical, mostly and pad will do - so choose the one you feel like suites you the best.![]()
I'm with you on the Goliathus, great pad. I'm rocking the control edition on my DeathAdder, I prefer a slightly grainier texture to a smooth texture, so it gets the job done nicely.Originally Posted by ChristianEx;14177750
im guessing it would be fine since it tracks gr8 on my thunder9 pad which WAS black but now after some 5-6years of wear and tear its actually gotten shiny if you directly under some lights.Originally Posted by FlipBack;14202137
Do you guys think I will have problems on my Steelseries 9HD? It's black but it has small gray steelseries logos all over.
Haven't gotten my Spawn yet, also waiting on amazon.
Thanks! I've been thinking about getting a larger mouse pad and transitioning to cloth. Gonna hold off a bit on that though.Originally Posted by ElectricDelta;14205683
The 9HD works fine, tested here (FW Ver. 32). I have switched to cloth pads though, some time back, currently using the Mionix Sargas 460. It's pretty nice, and almost solid black. The graphics on it are very small and located towards the corners, so they never get under the sensor during gameplay. The Sargas seems to be higher quality than the QCK+ (which also works just fine with the Spawn). That's not a dig, the QCK's are very good, especially for the price. The Sargas 460 seems to have slightly more friction than the QCK's do, if that's something you're looking for. The Puretrak Talent is another great choice.
