1 - 6 of 6 Posts
so i'll be jumping on board with GPU Coin tomorrow and we're doing -n
whats the best -n miner for windows 64bit?
i've got some modified cgminer i used for ultracoin but not sure if theres something that blows the others away.
can you share your ultracoin miner?
Not new to Overclock.net
From the GPU Coin dev
Vert miner is compatible and since it's so well documented there shouldn't be any issues with people setting up their miners. Ill post links in the OP for people to figure out their setups.
Trying to find out if sgminer works as well as I'm lazy to make new configs and install new miners
Discussion Starter · #6 ·
looks like the vertcoin miner is the one to use.
here is the latest version and i have a test bat file in there for a coin that uses the same -n
https://www.dropbox.com/s/yli28ywnc6muhue/GPU%20Coin.rar
dont bother with mining on it long for me, its a pool i just signed up to so i could see if i could get my settings right.
just get your settings right and make sure you're not getting errors.
1 - 6 of 6 Posts
