BEST OC program?
664 5
what is the best overclock program for nvidia graphics cards?
Im going to OC my old BFG 5500 256mb card. This is gonna be my first graphics OC.
1 - 6 of 6 Posts
CoolBits, and then test with a benchmarking program, or use ATiTool.
nahh id say nvtweak or................ riva tuner links here and make sure that on riva tuner u max out your fan speeds.. also make sure you have the 6.1 drivers.. http://downloads.guru3d.com/download.php?det=911 http://www.guru3d.com/rivatuner/ make sure you only jump in baby steps by atleast 5mhz core and 10 mhz memory... dont be fooled because some cards can go very high depending how well that certian one was made.. also those cards im pretty sure have locked pipelines correct me if im wrong and i think they can be opened by riva tuner.
Go with atitool, u know why, u can find ur max core, and memory plus after all that u can scan for artifacts. Thus it will overclock ur card safely.
1 - 6 of 6 Posts
