FSB x Multiplier = CPU speed
FSB x Divider = Memory speed
So, with linked memory, when you increase the FSB you speed up both the CPU and the memory.
Any combination of FSB and multiplier that gets you to where you want to go is fine.
A CPU at 4.0 ghz doesn't know whether it got there with a 400FSB and 10 multi, or with a 472 FSB and an 8.5 multi. (you may see some slight performance differences at the same CPU speed with a faster FSB/lower multi, but you'd have to benchmark to see them.)
As for overclocking, when you change the multi by 1 you change the CPU speed by whatever your FSB is ( ie. 400 x 7 = 2.8 ghz, but 400 x 8 = 3.2 ghz. a 400 mhz change), but if you change the FSB you change CPU speed by whatever your Multi is (ie 400 x 8 = 3.2 ghz, 401 x 8 = 3.208 ghz, an 8 mhz change). Changing the FSB gives much finer adjustments.
