Best overclock settings for 3770k on air?
365 Views 3 Replies 2 Participants Last post by  BeastRider
Hello!
First I'd like to say that Ive updaded my BIOS and the .CMO file with my overclock settings wont load anymore. I wish I could open it somehow to check how my overclock was, but unfortunately, I dont know if thats possible.
Since my last overclock it's been a while so I presume the best settings for 3770k have been all figured out already.
I was hoping you guys could help me achieving the best I can from my cpu with a hyper 212 evo cooler.
I usually kept it at 4.5 ghz, however I cant remember any of the othe hundreds of mobo settings...
Thank you!
1 - 4 of 4 Posts
Each chip is different so there is technically no "best setting" that would fit all 3770K's. My advise would be to follow this guide to get your best possible overclock. 4.5GHz sounds like the best you can get with your cooler. Mostly only the turbo voltage offset needs to be increased in tandem with the multiplier until you get a stable clock. You don't have to tweak many other settings.
Cheers.
Hey thanks!
I was wondering if there's one of those for asus mobos?
Originally Posted by dream3 View Post
Hey thanks!
Not really sure, you can try using the search bar but the AsRock guide works for all mobos. It's the same concept, the only difference is probably the labeling and layout of the BIOS. You can follow the guide step by step as well.
Cheers.
1 - 4 of 4 Posts
