Best Power Supply..........??
1700 39
Anyone have any suggestions on what the best power supply choice is for around $200, possibly $250?????????
Status
Not open for further replies.
1 - 20 of 40 Posts
Originally Posted by kaxx
Sweet, I do like the price on that one better...........the reviews don't seem solid.........i guess you take a chance that you get one that works. Or you can send it back
IMO there shouldnt be a problem.
PSU's die because of heat.
The peoples whos psu's died were prolly overheating there case or w/e.
Ive seen at least one reviews on newegg for pretty much EVERY psu that ive seen where one blew up.
And if your that worried just run the psu overnight or something without it being plugged into anything.
Or even better get a bunch of fans and make it so they can run on the 12v 5v and 3v so that the psu is being used but no expensive components are at risk
Originally Posted by tytlyf
steveo took the link out of my mouth....probably the best brand available for psu's. If your budget is 2-250, then that's the choice.
I wouldnt say its the best brand.
But its one of the top 5.
Nor would I say there is a best brand.
Discussion Starter · #13 ·
Find a professional review anywhere that had a bad experience with the Seasonic and i'll believe it. Until then, Newegg "reviews" have about as much validity as Bill Clinton. I'd be willing to bet that 1/2 of the reviews on there are from people that have never even seen a Seasonic nor used one.
Expensive, but looks good.
What do you guys think of this setup for overclocking my Sempron 2800+ with Biostar TForce 6100 754 board?? Any suggestions are definitely a big help, but keep in mind this price range is currently out of my budget as is
http://www.newegg.com/Product/Produc...82E16817703001
http://www.newegg.com/Product/Produc...82E16835106038
http://www.newegg.com/Product/Produc...82E16835100007
http://www.newegg.com/Product/Produc...82E16820227219
I think you're going overboard on the power supply. Having a nice one is very important, but you're overkilling your needs. Get this one and put the extra savings into a different upgrade or save it for your next system. It will more than handle your machine and anything you add to it.
http://xoxide.com/sunbeampsu.html
That looks great sccr, thanks for the info!!!!
That's an extremely well built power supply and is a very good buy under $100. There are several members here running it and I have yet to see a single negative remark. It can prove to be hard to find in stock though, so be patient. It sells out frequently.
1 - 20 of 40 Posts
Status
