1 - 20 of 40 Posts
i was thinking of buying an APEVIA ICEBERG ATX-IB680W-GN 680W Power Supply and a HIS H679F1GD Radeon HD 6790 Video Card for my current build ''a small build'' but want to make sure im getting the best i can performance and cooling wise (small case) i know apevia is kind of an off brand but ive owned 5 of there PSU's and all have worked well (one was a little loud) i chose it for the fan configuration so it doesn't take direct heat off my video card and the card i chose because i thought it would run cooler than the 6870 i chose the first round so right now im looking for ideas
Not New to Overclock.net
Originally Posted by Schmuckley View Post
well..your original choices are pretty good at that price point..i'd try to find an EOL 5850 or 5870 deal if possible..maybe look for a 460 deal..just to get best bang for buck
http://www.aztekcomputers.com/01GP31366RXCOR-EVGA-2447910.html
http://toolscameras.com/index.php?main_page=product_info&get=topbaile&products_id=11993&zenid=p7qd7qfepq8tksppe8jl30cmk1
I would normally agree with you but the 5000 series is higher thermal output than the 6000. And I can't recommend Nvidia products, I don't use them or keep track of them.
@Schmuckley yeah i saw a galaxy 460 on newegg for 120 but it sold out in 3 days and neither of the 58's out preform a 6870
@TheJesus that is helpful
Discussion Starter · #11 ·
4eggs at 4000 reviews but only one 6pin (cable cludder) i could just keep my antec at that
OG AMD
that's false. 5800>6800.. they have more shader cores + are overclockable you have a 6800? wanna go do some furmark right now?
Honestly, if you can put up with rebates and don't mind coming in below $200 in the end, I would get these:
CORSAIR Builder Series CX600 $70 | Use code EMCNJJC63 to bring it to $58 | Mail in rebate brings it to $38
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
XFX Double D HD-6870 $170 | Mail in rebate $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521&nm_mc=EMC-IGNEFL011712&cm_mmc=EMC-IGNEFL011712-_-EMC-011712-Index-_-DesktopGraphicsVideoCards-_-14150521-L04C
When you get the rebates back in your total is $188
Or, you could get a GIGABYTE 6850 for $140 and after rebate it's $120 your total for that would be $158
. Which will leave you some room for w/e you want.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125353&nm_mc=EMC-IGNEFL011712&cm_mmc=EMC-IGNEFL011712-_-EMC-011712-Index-_-DesktopGraphicsVideoCards-_-14125353-L04B
Discussion Starter · #16 ·
the xfx card is too tall for my case and id have to wait for the rebate before i could buy the next item
http://www.anandtech.com/bench/Product/294?vs=290
Not by much, they also have higher TDP and power consumption. He wanted the cooler card, thus 6000 series. The performance is pretty similar, so no big deal.
1 - 20 of 40 Posts
