1 - 20 of 23 Posts
Hello everyone, it was my birfday recently
and i got some cash.... so ima throw it in my computer. I was hoping to get a 4850 but i lack the powersupply to run one. So What is the BEST Powersupply i can get for 50$ Shipped that will run a 4850 stable?
I found
http://www.newegg.com/Product/Produc...82E16817139008
It looks great.. 39 bucks shipped after promo plus rebate so thats 29 dollars... its a steal... and its got a fan to keep my card cool too. Im worried it does not have enought amperage though, only 30 AMPS on its Single 12V Rail.
Any help would be greatly appriciated
30 amps is more than plenty; I've run a 4830 on 18 amps. At $30, that Corsair is a great deal. However, any future upgrades might get held back by the measly 400w. A 650w is $70 but it'll cover you in the future when you upgrade.
Either way, Corsair is the way to go. And happy birthday!
Originally Posted by j0z3 View Post
Get a OCZ 500/600w StealthXStream.
The single rail Corsair @ 30 amps is better than the dual rail OCZ at 18A/18A.
haha, this is how it starts.....
back in the day i planned on swapping my HP case out and buying an ATX mobo for my old 4200+ so i could OC/crossfire my x1950PRO in the future if need be.
but instead i built an entire rig.......and then 8-9 months later invested another $1200(including monitor) into it to what it is today
stop now or forever hold your peace
The Fabricat0r
The OCZ 500/600W have 34A/44A combined respectively. They would have no problems running a 4850.
I never said that they would NOT run the 4850. I just said that I would rather have a single rail PSU that is more stable than a PSU with multiple rails, especially OCZ PSUs that have a high "ripple" factor (unstable as you approach load).
Great choice in PSU. Definitely one worthy of recommendation.
The Fabricat0r
How exactly is a single rail more stable than a multi-rail? Please be specific (and please don't link to PC Power myths as the basis for your reasoning). Under real world conditions there is little difference between the two. 99.9% of the time, the number of rails in a non-issue.
And last time I checked, the 500W and 600W FSP Episilon based OCZs were able to stay within spec for ripple. The 500W is well within spec and the 600W sees levels similar to the much praised Corsair tx750. Certainly the cx400 is the better built unit, I was just correctly pointing out the capabilities of the OCZs.
And last time I checked, the 500W and 600W FSP Episilon based OCZs were able to stay within spec for ripple. The 500W is well within spec and the 600W sees levels similar to the much praised Corsair tx750. Certainly the vx450 is the better built unit, I was just correctly pointing out the capabilities of the OCZs.
I consider myself lucky that my power supply hasn't done anything since I've bought it last summer when I built my rig.
I guess I'm running my 4850 @ 18 AMPS right now then, since it only takes 1 power connector, right? Could this cause my GPU to not work at it's full potential? I wish I would've gotten a different power supply but I didn't do my research on this one.
The Fabricat0r
No way, it will only draw what it needs. Even a heavily OCed 4850 wouldn't go much past 130W. That is distributed between the PCIe slot and the PCIe connector, both of which are on different rails. 130W or ~7A divided across two 18A rails is nothing.
1 - 20 of 23 Posts
