I have the corsair H60 in a silverstone ft02 (radiator is placed horizontal on the top with airflow directed from the bottom of the case out through the top). I'm looking to replace the stock fan, which I find rather noisy with a push-pull setup.
I've noted the following 3 as options:
Scythe Gentle Typhoon 120mm x 25mm Fan - 1850 RPM
Noctua NF-F12 PWM
Enermax T.B. Silence 120mm x 25mm "Twister Bearing" Fan
I would love to hear feedback on what would work best with my setup taking into account the need for high static pressue for the radiator, cooling and reduced noise.
thanks!
Noctua NF-F12 PWM
thanks!
