Originally Posted by ghettogeddy
well thats what im getting at is 64kb better then 128 or vise versa, short stroking really make that much of a differance, cause i can use ultimate defrage to consolidate info to the outer most part of a platter, thats all the short stroking does is put the info to the outer parts of the drive correct
Like I said, it depends on your usage.
Real-world performance, with 3x HDD in RAID-0, I really don't think you're going to notice tremendous differences in performance with varying settings. 128KB stripe sizes are fine for general use. For example, selecting the right cluster size when you format will also make a slight difference. Smaller cluster sizes saves a bit of space, but slows down a bit 'cause more clusters have to be read for each file. Larger files are read a bit faster because fewer clusters are involved, but you can potentially end up with more wasted space.
If you're into benchmarking just for fun... then you're really just going to have to do it by trial-and-error. Seriously, I doubt anybody here has the *exact same* usage habits as you (we're all individual in our computer uses, yes?)
I personally don't short-stroke my HDDs because I'm not that critical about HDD speed. I have 4x 500GB WD Blacks in RAID-0 and it's fast enough for what I do, and I really don't care about trying to squeeze another oh, 5MB/sec out of my array (just as an example).
If you're a performance nut ('cuse the language), you should just invest in a couple of Intel SSDs in RAID-0 for absolute maximum performance.
