Best RAM for overclocking?
2218 Views 22 Replies 16 Participants Last post by  melantha
post links and reasons! go!
1 - 20 of 23 Posts
any wellbuild Gskill, Corsair, OCZ will do perfectly fine,
they all have great potential to OC like a beast
EDIT
forgot to say mushkins are BEASTY as well
After much thought of which RAM I should get for my Phenom II 955/MSI 790FX-GD70 build..
I decided to go for these once I get some extra cash:
2x2GB OCZ Platinum 1.65V DDR3 1600
[Look into lower voltage RAM, which is beneficial for overclocking that it provides more headroom.]
I like giel ram it's very underrated an is extremely good ram defiantly worth a look at
I really don't like Corsairs RAM as they have failed on me twice. I'd get some G.Skill RAM, they always make good stuff. But really any high end OCZ, G.Skill or Mushkin RAM will do.
OCZ Platinum (7-7-7-24) !!!!
nothing special. he said the "best" ram for overclocking.
I run Gskills on mine. 1ghz overclock with my rig. Just click my cpuid at the bottom. The only link necessary.
I've got some g.skills as wel cna do 1600mhz at 9-9-9-24, right now they are clocked at 6-6-6-20 800mhz
any good ram specially made for AMD?
i was thinking going OCZ, the AMD Black edition
Get anything with really tight timings for AMD systems.
Originally Posted by _Marvin_
never buy HyperX
my kingston hyprerx came with d9gkx and does 1333mhz ez
your statment is void
i use any ram with the right chips and pcb design
it dont matter who made its the chips that matter most
tighter timmings and high voltage? or tighter timmings with low voltage?
Lower voltage is always better. It's not like with higher voltage, you're RAM is actually going faster (at the same speed as low voltage).
whats so impressive about running 6400 ram at 800mhz 5-5-5-15? lol
answered your own question there buddy
1 - 20 of 23 Posts
